Home » Sponsored » Pi Speakers » Paper veneer
Re: Paper veneer [message #69726 is a reply to message #69725] Wed, 05 October 2011 22:26 Go to previous message
I want to be sure I understand: you're gluing veneer side to cut edge and the veneer is peeling? If so, you either have to start over, peeling off all the veneer, or, as you said, use screws every 3" to make the bond. Once done, you'll need to silicone caulk every MM of joint inside the cabinet.
Too bad you didn't find the laminated pine tabletops Depot has instead of the shelving. I once planned a Theatre 4 made out of the 36" and 18" widths by 48 and cut with a toolbox saw!
Previous Topic: hole saws
Next Topic: 3 Pi Crossover/Plans Question
Current Time: Fri Oct 16 05:32:35 CDT 2026
