Home » Audio » Speaker » Ultimate Dipole Line Array
Re: Ultimate Dipole Line Array [message #69696 is a reply to message #69339] Tue, 04 October 2011 09:01 Go to previous messageGo to previous message
But you don't listen to a line array at one meter. The listening position distance should be at least the length of the array, and ideally more than that. So here's the same in-room response of the twelve woofer array measured at the sofa, which is ten feet from the speakers. You can still see the 5-6khz peak, but the overall response is much smoother at this distance.
It is now possible to see how you could include a tweeter that would integrate fairly well with this array, but it's obvious it will need a low fs for a crossover frequency no higher than 2khz, it will have to be fairly efficient to match the woofer arrays's sensitivity, and you will need to use a higher order crossover to get it to play fairly loudly down to the crossover frequency.
index.php?t=getfile&id=610&private=0
Previous Topic: Charge Coupled Crossover Capacitors
Next Topic: The most expensive speakers in the world
Current Time: Fri Nov 06 07:32:00 CST 2026
