Home » Sponsored » Pi Speakers » Alpha or Delta 10?
Re: Alpha or Delta 10? [message #69664 is a reply to message #69658] Sun, 02 October 2011 01:52 Go to previous messageGo to previous message
sippy is currently offline  sippy
Well, I'm currently enamoured with a mint condition Cryus 2 + PSX, but despite being quite handy with a soldering iron, I've always found valve amps a bit scarey re voltages and amps - I'm leaning towards building a Pass DIY F5 or a battery powered Gainclone with maybe an Oatley Electronics JAN 6418 pre kit set up as a buffer.
The F5 scores because theres been plenty built, pcb's and matched active device kits are easily sourced.
Battery Gainclone/6418 buffer fits in with a modified Playstation 1002 project - ive already got a late PS running from batteries, sounds worlds better than the stock surply but not quite as good as the stock early model.
My usual front ends are a Marantz CD63KIS or PC-soundcard-flac.
Current speekers are 92db/w/m floorstanders and the Cyrus never gets run above half power - the neighbours need to be able to listen to their music.
your thoughts would be most welcome
Previous Topic: 4 Pi and 3 Pi Subwoofer
Next Topic: Changing the room...
Current Time: Sun Oct 04 13:15:05 CDT 2026
