Home » Sponsored » Pi Speakers » hole saws
Re: hole saws [message #69652 is a reply to message #69651] Fri, 30 September 2011 17:48 Go to previous messageGo to previous message
Depends on the hole and where you are, spelling favorite with an "U" tells me UK and brands will be different. If you're talking about wood, I like the Rigid Brand hole saw bits that have a separate arbor with 2 protrusions that insert into holes on the cutter as you tighten it onto the arbor. Hole saw cutters that come attached to an arbor at a low price soon come adrift.
Except for repeated sizes like Terminal cups and 4" vent pipe, I use my router and a trammel to cut even small holes. Quick, easy and no limit to size.
Previous Topic: How I spent my weekend...
Next Topic: Paper veneer
Current Time: Fri Oct 16 06:28:26 CDT 2026
