Home » Sponsored » Pi Speakers » New HT - Need Advice on Speakers - 4pis or 7pis for main, 2pis, and what to use for bass
three π verses four π [message #69418 is a reply to message #69415] Fri, 09 September 2011 10:23 Go to previous message
I tend to try and refrain from giving my subjective opinions on the comparisons between the JBL 2226 used in the four π speaker and the AE TD12S used in the three π speaker. I just think too highly of both models. I don't hesitate to point out the benefits of midwoofers that have shorting rings, which is why I suggest the upgraded drivers over the stock ones. But once you get into the upgraded drivers, you're into the realm of what I consider to be the best speakers you can build or buy. It just doesn't get any better than that, both models are superb.
I sometimes make the comparison to cars. Which would you prefer, a Ferrari F40 or Porsche 959? Both are world class cars, both exceed 200MPH. It is like this with the fully upgraded three π or four π speakers too.
The four π is 3dB louder at the same input power, and is slightly smaller. Other than that, the differences are mostly below 100Hz, where multisubs should be employed. And once the subs are in place, it almost doesn't matter what the mains are doing. But below 100Hz, the 2226 shifts a little bit as power is increased. At very low power levels, it has slightly reduced bass. Again, when flanking subs are used, this just doesn't matter.
Above 100Hz, the two speakers are virtually identical in sound character and quality. Their directivity patterns are similar, their spectral balance is similar, in all respects, they are very much the same.
Previous Topic: 4Pis are back and I wrote a BOOK!
Next Topic: Contemplating a change
Current Time: Fri Oct 16 18:57:18 CDT 2026
