Home » Audio » Room Acoustics » Furniture & Room Sound
Re: Furniture & Room Sound [message #69405 is a reply to message #69391] Thu, 08 September 2011 21:32 Go to previous message
Hi, It does so in a big way. Sometimes it is to great advantage - if you have a very reflective room some overstuffed furniture can tame it. If the room is fine as is and you add some of the same type of furniture then you can end up with rather dull sound. This is a problem with HT setups as the norm seems to be lots of fluffy furnishings. Good to sit on Smile , bad for sound Sad
Previous Topic: Oddly Shaped Rooms
Next Topic: More sound up front?
Current Time: Sat Nov 07 03:34:26 CST 2026
