Home » Sponsored » Pi Speakers » Contemplating a change
Re: Contemplating a change [message #69400 is a reply to message #69392] Thu, 08 September 2011 18:01 Go to previous messageGo to previous message
When I switched to the B&C drivers, I only one speaker first, and A/B'd them for myself and some friends, and people couldn't believe the difference, mostly because they had all really liked the PSD2002's and couldn't believe it was the same. If cost is an issue, the Eminence is great value, and you'll be able to tell if you like them. The B&C is well worth the extra bucks if you can swing them. You might be able to find some used Eminence's to try easier than the B&C, as well, since they're used in pro sound a lot. H290 is a nice horn- nothing fancy, but very smooth & clear in this app.
Previous Topic: New HT - Need Advice on Speakers - 4pis or 7pis for main, 2pis, and what to use for bass
Next Topic: Discussion on waveguides / horns
Current Time: Tue Nov 03 10:58:43 CST 2026
