Home » Sponsored » Pi Speakers » Contemplating a change
Re: Contemplating a change [message #69393 is a reply to message #69392] Thu, 08 September 2011 14:51 Go to previous messageGo to previous message
Don't use an H295, it's a spitty and nasty sounding. If you go from a tractrix horn to that thing, you'll think constant directivity is responsible and we'll lose you forever. Laughing
Get an H290. It's a radial horn, with nearly constant horizontal directivity and gradually collapsing vertical directivity. That's just what you want in a speaker like this. I might also suggest using a DE250 driver instead of the PSD2002. The PSD2002 is a great driver for the price, but the DE250 is so much smoother, it makes a better speaker. Not a lot more expensive either. I'll send plans if you're interested and you can get the parts on order, build the crossover and give it a go.
Previous Topic: New HT - Need Advice on Speakers - 4pis or 7pis for main, 2pis, and what to use for bass
Next Topic: Discussion on waveguides / horns
Current Time: Tue Nov 03 12:26:16 CST 2026
