Home » Sponsored » Pi Speakers » Should I build (2 or 3) 4Pi Mains?
Re: Should I build Two or Three 4Pi Mains? [message #69308 is a reply to message #69306] Sat, 03 September 2011 00:05 Go to previous messageGo to previous message
Maxjr is currently offline  Maxjr
Wayne Parham wrote on Fri, 02 September 2011 22:59
Our plasma TV is 50" also. The speakers are outside that, angled in as described in the "High-Fidelity Uniform-Directivity Loudspeakers" whitepaper. There is absolutely no need for a center channel using this setup. Personally, I wouldn't even consider a center channel unless the seperation between R/L channels was greater than 20 feet.
index.php?t=getfile&id=445
Thank you for the clear and succinct response, Wayne! I'm happy to hear this and only build two as that will reduce the costs by 50% ! I need to rereading that Hi-Fi Uniform Directivity Loudspeaker whitepaper again. Very Happy
Previous Topic: 1/2 PI Crossover
Next Topic: 4pi and 2pi plans
Current Time: Fri Nov 06 02:41:16 CST 2026
