Home » Sponsored » Pi Speakers » 4pi Commercial Dinner Theater Build
Re: 4pi Commercial Dinner Theater Build [message #69292 is a reply to message #69284] Fri, 02 September 2011 09:07 Go to previous messageGo to previous message
Wayne: Thank you for your patience as I get past the learning curve. I learn quickly; but there is much to learn. If I understand what you say correctly:
1. The F20 subs on the west wall can function as the "distant subs". I see that you suggest a high pass at 60Hz. Would a high pass at 80Hz be troublesome for the distant subs?
2. If I build two 3pi subs, then I should place them at the back floor of the stage wall slightly offset from the x coordinate in relation to the mains?
3. Are the drivers pointed at the audience in this configuration?
P.S. Did you see my question about how much lead time I should give you for all of the components I will end up needing?
Thanks again!
Previous Topic: Audition in Austin
Next Topic: $5 drivers as computer Pis
Current Time: Fri Oct 30 07:17:30 CDT 2026
