Home » Audio » Thermionic Emissions » Buying Amps on eBay
Re: Buying Amps on eBay [message #69266 is a reply to message #69262] Thu, 01 September 2011 09:39 Go to previous messageGo to previous message
Danny is currently offline  Danny
Well, first, you will go by the specs. And then you will make sure you are buying from a reputable seller. I have actually had good experiences from shopping on eBay.
Previous Topic: What are the common issues that you've experienced with using different tube amps?
Next Topic: Tubes from Russia
Current Time: Fri Oct 23 19:56:51 CDT 2026
