Home » Sponsored » Pi Speakers » Damping material placement
Damping material placement [message #69265] Thu, 01 September 2011 09:25 Go to previous message
doucanoe is currently offline  doucanoe
I was wondering what you recommendations are for fiberglass lining of the walls in the 4pi using the 2226. Which walls, thickness of batt material, etc.
If it matters, I constructed my pair using a 2.8-3 cu-ft LF sub enclosure tuned to 38 Hz for the 2226. Although I'm pretty darn pleased with the LF performance, I do believe I may have the enclosures a little over filled.
My original plan was to go a little heavy initially then reduce and note the changes. Then, settle on what I thought sounded best. Things sounded pretty good right from the get-go so I never made any changes. It's been a while so I would have to pull a driver to even tell you how I went about lining the cab.
I've tried to do some searching for the answer here (I'm sure you have addressed it a million times by now) but having a little difficulty finding anything that speaks to it directly.
Thanks,
RC
Previous Topic: crossover board assembly
Next Topic: 1/2 PI Crossover
Current Time: Sat Nov 07 23:31:35 CST 2026
