Home » Sponsored » Pi Speakers » 1pi or 2pi for surrounds?
Re: 1pi or 2pi for surrounds? [message #69211 is a reply to message #69207] Sat, 27 August 2011 09:32 Go to previous messageGo to previous message
I like to cut the port holes on the baffle so the port tube fits snugly in them. Cut the port to the proper lenth with a table saw and apply a thin film of white glue on the edge to protect it. Put white glue on the baffle edge where the port goes and press it in flush to the baffle, wiping off any excess glue.
I also like to paint the interior of the port. You can do that with an aerosol can before gluing it in or you can use a paintbrush after assembly. If you spray paint the inside of the port, protect the outside where the white glue will be using masking tape. The cardboard adheres best when it isn't covered with paint.
Previous Topic: Flanking subs and phase
Next Topic: Pi 3 or 4?
Current Time: Mon Oct 19 21:42:34 CDT 2026
