Home » Sponsored » Pi Speakers » Midrange Horn
Re: Midrange Horn [message #69201 is a reply to message #69200] Fri, 26 August 2011 18:09 Go to previous messageGo to previous message
It depends on the thickness of the veneer. If you're using thin veneer, you can cover the entire side before assembly. But thick veneers will create enough offset the pieces won't fit together well so you have to trim to fit. On those, it's best to cut the veneer to size before assembly, but don't actually attach it until after assembly. Honestly, the thinner veneers are easier to use for the flare pieces. Save the thicker stuff for the cabinet sides.
Previous Topic: How good is the 1Pi? Pretty good, I think.
Next Topic: I covet the 7Pi Plans...
Current Time: Mon Oct 19 14:10:29 CDT 2026
