Home » Audio » Craftsmen » Repairing a Barrel Construction Drum
Re: Repairing a Barrel Construction Drum [message #69173 is a reply to message #69085] Thu, 25 August 2011 03:34 Go to previous message
LizardBat is currently offline  LizardBat
Awesome! That sounds like a great project! Be sure to remove as much exposed dried glue from the planks as possible before repairing it, so that there are no gaps between planks. Using the ratchet straps is good idea, just be sure they don't slip off and you put a towel or something between them and the drum shell.
Previous Topic: Tuning Vents and Resonators
Next Topic: Necessary Tools
Current Time: Fri Oct 16 04:24:41 CDT 2026
