Home » Sponsored » Pi Speakers » Information about Pi Speakers
Re: Information about Pi Speakers [message #69102 is a reply to message #69101] Sun, 21 August 2011 08:17 Go to previous messageGo to previous message
Read the material below, and then do some searches here on the forum to help you decide which model and upgrade options to get:
Your decision should be based on room layout, desired performance and budget. The π constant directivity cornerhorns are the best option if you have the right room layout and corners. If not, the matched-directivity two-ways are your best bet. Either way, use multisubs for best performance. If the matched-directivity two ways are chosen, then use flanking subs, as described below:
Previous Topic: Pi8 plans
Next Topic: 2-Pi towers or 3-Pi's ?
Current Time: Tue Sep 22 08:36:36 CDT 2026
