Home » Sponsored » Pi Speakers » SCREWS?
Re: SCREWS? [message #68707 is a reply to message #68697] Sun, 24 July 2011 16:15 Go to previous messageGo to previous message
I used #6 1 1/2" wood screws on my first 4pi build. The #6 is a little narrower, which is less likely to split your plywood. The cabinet is perfect and airtight, and I used PL Premium on the joints before screwing them in.
My second 4pi build will be with Tightbond and clamps. I think the not using screws plan is more of an aesthetic thing than a structural thing, but I want to get good at glueing things. They are not kidding that Tightbond is easier to sand and clean (especially off your skin). If you do clamp them, I found 8 clams to be insufficient, and bought 4 more. Cost was about $15 USD each.
  • Attachment: IMAG0567.jpg
    (Size: 130.93KB, Downloaded 521 times)
Previous Topic: towers
Next Topic: Signal Wire for 4Pis
Current Time: Sat Nov 07 00:13:54 CST 2026
