Home » Sponsored » Pi Speakers » 4pi Commercial Dinner Theater Build
Re: 4pi Commercial Dinner Theater Build [message #68643 is a reply to message #68639] Tue, 19 July 2011 14:38 Go to previous messageGo to previous message
Answers by numbers:
1. Screws - Don't use them, use clamps instead. I only use screws in cabinets where removable clamps would be impossible or impractical to use. An example is the 12π hornsub, which has internal structures and panels that must be clamped, so we use screws to provide clamping pressure while the glue sets. We predrill the holes and put PL adhesive in the holes before inserting the screws. That makes sure the screws don't vibrate loose and that no internal void, split or chip is formed that might start buzzing later.
2. Baltic birch is fine.
3. No bracing is necessary, the cabinet is small and very rigid.
4. The kit contains port material. It's a thick cardboard tube that you cut to 3.5". Cut the port hole to match the OD of the duct and glue it in. Some people use plastic ducts, and that's fine, I suppose, but I prefer cardboard. It's wood pulp, just like the cabinet. I like to paint the inside of the duct black.
Previous Topic: Audition in Austin
Next Topic: $5 drivers as computer Pis
Current Time: Fri Oct 30 07:15:08 CDT 2026
