Home » Sponsored » Pi Speakers » Modifed 4 Pi Build Report (Design)
Re: Modifed 4 Pi Build Report [message #68577 is a reply to message #68575] Sat, 16 July 2011 15:37 Go to previous messageGo to previous message
Look for response blips in the midbass to midrange, from about 60Hz to 300Hz or so. Above that the insulation will work. You will want to use something that can measure amplitude response, although you can see evidence of the standing waves in an impedance sweep. That's a simpler measurement, however, it won't tell you how severe the peaks might be.
One thing that will help is to use a sheet or two of insulation spanning the cross-section of the cabinet, splitting the top and bottom of the cabinet (and maybe even in more than one dimension) in addition to the insulation that lines the walls.
Previous Topic: Setting 4pi LCR upside down in theater?
Next Topic: Looking for a few extra watts for your Pis?
Current Time: Thu Nov 12 14:49:27 CST 2026
