Home » Sponsored » Pi Speakers » Excited =)
Re: Excited =) [message #68559 is a reply to message #68558] Thu, 14 July 2011 22:16 Go to previous messageGo to previous message
Well I am kinda ticked at myself. I found some good primer I had sitting around and thought I would try some on a scrap piece. I put it on and it seemed amazing. It sanded well and covered evenly. Well after painting all my pieces I am now finding it doesnt sand for beans and I am having to work three times harder to get it done. I should have stuck with my original plan.
What I am noticing though is that I am sanding my pieces VERY well and the grain of the MDF doesnt seem open at all on the edges. Why would the edge be any different then the top? Its an all man made product and isnt like plywood in layers. Is it maybe sealed on the top and bottom in some way before you get it maybe?
If you have paineted MDF before what did you do?
Previous Topic: PI4 Build for home theatre
Next Topic: Any Pi builders in Ireland ?
Current Time: Sun Nov 22 23:51:27 CST 2026
