Home » Audio » Thermionic Emissions » Valve Phono Preamp
Re: Valve Phono Preamp [message #68444 is a reply to message #68442] Sat, 02 July 2011 18:31 Go to previous messageGo to previous message
Hm, I`d try half of that 113k value, say standard 56k. As you said, suprisingly, there are not too much RIAA deviation with some resistor values changes (tenths of dB, or 1 dB "over" 20 Hz in your case), but those deviations are in "wide" frequency spectrum and can be heard.
Quick calculation gives Rout~28k from SRPP (must be measured or at least calculated and/or simulated), and when we use about 56k for series resistor in parallel with 1 Meg, this gives:
R = (28+56)x1000 / (28+56+1000) = 77,5 k , about right.
Previous Topic: Guitar Amp
Next Topic: KT120 Class A U/L Mono-Blocks
Current Time: Sun Oct 25 13:36:27 CDT 2026
