Home » Audio » Speaker » Electro Voice TL-606 enclosure with 3 PI components?
Re: Electro Voice TL-606 enclosure with 3 PI components? [message #68228 is a reply to message #68174] Fri, 17 June 2011 23:24 Go to previous message
The TL-606 cabinets were made for a the EVM 15L's and EVM EVM 15B's (15" drivers), which didn't do anything below 60hz. But there'a an advantage, which is being able to change the baffle board size to adapt the Delta12's which Wayne mentioned. You have between 2.89 cu ft 3.1 cu.ft. to work with based on the size of the driver. Then port length will be based on what freq. you want to tune the cabient to. Run computer simulations like Wayne said, you'll see.
Previous Topic: MTM series or parallel
Next Topic: The Karma Indignia
Current Time: Fri Oct 16 00:59:20 CDT 2026
