Re: 4 Pi Home Theater Build [message #68207 is a reply to message #68206] Thu, 16 June 2011 22:23 Go to previous messageGo to previous message
Finally, two coats of primer (first coat white and second coat gray). Starting to see the light at the end of the tunnel.
index.php?t=getfile&id=504&private=0
index.php?t=getfile&id=505&private=0
index.php?t=getfile&id=506&private=0
index.php?t=getfile&id=507&private=0
Tomorrow - or Saturday - will veneer the cabinets. Going to try the "Better Bond Titan DX™" Contact Cement from veneersupplies.com. Since most of the work is in my home theater I wanted to avoind VOC's, reviews of Titan DX on the net have been good, so I decided to go for it. Also, need to sand the primer and add a third coat.
The plan is to paint the front/rear baffles and stain/seal the veneer once I arrive in Cambodia, not enough time for paint/polyurethane to cure before they will be packed for shipment.
  • Attachment: 020-40.jpg
    (Size: 106.83KB, Downloaded 7922 times)
  • Attachment: 01940.jpg
    (Size: 84.44KB, Downloaded 7922 times)
  • Attachment: 023-50.jpg
    (Size: 170.16KB, Downloaded 7973 times)
    (Size: 170.16KB, Downloaded 7933 times)
VIRIBUS MARI VICTORIA
Current Time: Sat Nov 21 19:47:38 CST 2026
