Home » Audio » Speaker » MTM series or parallel
Re: MTM series or parallel [message #68122 is a reply to message #68081] Fri, 10 June 2011 08:01 Go to previous message
Wiring in parallel increases the overall sensitivity, so if your mids are lower in SPL, then that's the way to go. Series increases the maximum voltage since the two form a voltage divider so if the mids can't handle much power, wire 'em that way. I wouldn't say I have a "preference", but that's the difference so if the specs lean one way or another, you can adjust accordingly.
Previous Topic: Speaker Screens
Next Topic: Electro Voice TL-606 enclosure with 3 PI components?
Current Time: Wed Oct 21 04:16:56 CDT 2026
