Re: 4 Pi Home Theater Build - Primer and Paint Questions [message #68003 is a reply to message #68000] Thu, 02 June 2011 19:11 Go to previous messageGo to previous message
This is not my specialty, which is why I didn't reply right away.
The one product I have a lot of experience with is Duratex. It can be put on the raw wood and it will seal and finish coat it in one step. It's very durable and so if that's what you're after, it's probably your best bet. All the prosound speakers use it.
You can also use the "Truck Bed Liner" product sold at Wal-Mart stores. It is as durable as Duratex. Easy to apply with a roller. They also have an aerosol produce available, but the coverage isn't nearly as good.
On the other hand, I understand some people use primer and finish coats like what is done to paint cars. That is probably a more attractive finish, and can be done in any color.
Current Time: Sat Nov 21 19:47:49 CST 2026
