Home » Sponsored » Pi Speakers » 3 Pi Subwoofer Plans
Re: 3 Pi Subwoofer Plans [message #67957 is a reply to message #67947] Tue, 31 May 2011 08:52 Go to previous message
The third dimension is depth, of course. If you are using the same horn and it is mounted to the same baffle, then that part will remain constant. But if you change horns or do anything else that would change the depth, you'll change the path length from source to listener.
Previous Topic: Plans and question
Next Topic: Here's a peek at the new speakers
Current Time: Mon Nov 16 00:16:31 CST 2026
