gofar99 Messages: 2059 Registered: May 2010 Location: Southern Arizona
Hi Everyone, The KT120 amps were in use for a while at the LSAF. As you might expect, they really put out serious sound. The design process is on going and a number of refinements underway. These are shaping up as mega power amps (at least for a class A tube design. Power output is coming up to spec in the 40-45 watt RMS range. They are so mighty that one smoked my test load bank. The smell of smoldering plastic was the first clue. Oops. I have some upgraded parts on order and expect the design to be finalized in about 2 months. Kits will follow at a later date (it takes time to source things like circuit boards and chassis). In accordance with the way I design, as soon as the design is finalized I intend to post it under group builds as a diy project for those of you who like to build from scratch. My experience is that there are at least two types of audio enthusiasts, those who build from scratch and those that don't. I like to cater to both.
