Home » Sponsored » Pi Speakers » 12pi bass horn plans
Re: 12pi bass horn plans [message #67863 is a reply to message #67861] Thu, 26 May 2011 09:11 Go to previous messageGo to previous message
The 12π hornsub uses a patented cooling plug/plate system that fits our OEM woofer. You can machine other parts to fit, but it is a non-trivial matter because you'll probably need to recone. I used to try and machine complete woofers, using the magnet to help capture the debris. But ultimately, there were too many failures going this route. It is best to machine the parts before assembly.
As for the electro-mechanical specs and suitability in that regard, I suggest using Hornresp to model the horn with your proposed woofer. I'm confident that it will give you an accurate picture. Then, of course, the real proof of the pudding is in the finished physical model. Measure it to see if it does what you want it to do.
Previous Topic: Optional Drivers and Upgrades
Next Topic: Recessed baffle and speaker grills
Current Time: Tue Oct 20 13:51:37 CDT 2026
