| Re: Time to set up the new room! [message #67786 is a reply to message #67531] |
Sun, 22 May 2011 10:53  |
gofar99
Messages: 2060 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi, Setting up a room can be a real trip. I've done it twice in the past year and it has come out fine. I have a program (MS Excel) that can help. You plug in the room dimensions and a few other things and it gives you a graph of the nulls and peaks. It does a pretty good job. With it you can fiddle with the listening position to fix a few things. I doesn't account for wall and floor coverings and similar things you might do to finish the job. I attached the program. The values in it now are just junk, so put in your own after you save it to someplace. I changed the extension to .xll as some browsers won't pass .xls ones (with good reasons).
