Home » Sponsored » Pi Speakers » So how does this all work then..? (I'd like a slice of Pi, please. But how?)
Re: So how does this all work then..? [message #67657 is a reply to message #67652] Mon, 16 May 2011 14:15 Go to previous messageGo to previous message
I think as long as you have baltic birch, your speakers will sound fine. They'll be lighter and more durable than MDF cabinets too.
I like to put four π speakers on 14" stands with 7° tilt back (pointed slightly upward 7°). The three π stand is a little shorter and tilted back a little less: 12" and 5°. Stands made this way will put the forward lobe right where you want it to be.
Don't put the speakers on stands unless you're running flanking subs. If you don't plan to use subs, put the speakers on angled risers, on the ground with the front about 3" and the back about 1". This will tilt them back and will avoid boundary self-interference. Push the speakers all the wall back to the wall behind them too.
Previous Topic: Sources for pre-fabbed boxes for One Pi and Two Pi Speakers
Next Topic: Spikes for 3 Pi and 7 Pi
Current Time: Fri Nov 06 06:02:26 CST 2026
