Home » Sponsored » Pi Speakers » Back EMF?
Re: Back EMF? [message #67443 is a reply to message #67442] Thu, 05 May 2011 14:38 Go to previous messageGo to previous message
Frihed89 wrote on Thu, 05 May 2011 13:31
I intend to buy the higher price mid-range drivers and tweeters from Germany or the UK. Is that what you mean?
Yes, the most important parts to upgrade are the midwoofer and tweeter compression driver.
I don't particularly relish spending a lot of money on cross-over caps. (The 2A3 that I am getting has no film caps at all. It is a single stage DC amp). Since I'll buy the cross-over units from you, already populated, I'll take whatever you give me. What are the standard grade caps ? Sonic-caps or something like that?
We maintain inventory of Erse, Solen, Jantzen (Cross-Cap and Z-Cap) and Auricaps. All are polys. When I get an order that specifies a particular brand, then I use them of course. But if not, I just use whatever I have most stock of. They're usually Erse or Jantzen Cross-Caps, but may be another brand. They'll definitely be high-quality poly caps.
My amps are: 12W Class A PP triode made by Jef Larsen, a 10W 300B integrated made by Audio Note (UK) and 3.5 W 2A3 made by Don Garber (Fi).
Excellent. Sounds very much like the amps I have in various rooms. I have an Audio Note Kit 2 (SET KT88), a Stoetkit (UL 6BM8) and an Image Audio (SET EL34).
Previous Topic: 4Pi crossover
Next Topic: Can I have the 4 pi plans?
Current Time: Tue Oct 20 21:56:55 CDT 2026
