Home » Audio » Craftsmen » Sealing MDF
Re: Sealing MDF [message #67285 is a reply to message #67284] Thu, 28 April 2011 22:06 Go to previous message
Yep, that Cambodia! I will be there for two years. Not sure about my housing - but I am fairly hopeful it will be air conditioned.
Already have the MDF all cut ready to glue (will use Titebond II). I am hoping that by using a shellac-based sealer/primer both inside and out of the cabinet the MDF will be adequately protected from moisture.
I have no experience with veneer and the hot iron method seems to be the easiest. However, I could paint as I would not be going for a piano gloss finish.
VIRIBUS MARI VICTORIA
Previous Topic: Veneer advice
Next Topic: Veneer advice (contd)
Current Time: Wed Sep 23 22:36:18 CDT 2026
