Home » Audio » Group Build » RIAA preamp project
icon14.gif  Re: RIAA preamp project [message #67230 is a reply to message #67167] Tue, 26 April 2011 11:15 Go to previous messageGo to previous message
Hi, A lot of thought went into the project Smile . I have been working for about 8 months or so on a RIAA preamp. I tried several variations and none have quite done what I want. I have no problem with gain, overload, Z out, frequency response. The one area I want is a S/N of over 90 dbv at 1 volt output. I can get 85 now. The best topology so far is a 12AX7 SRPP feeding a second 12AX7 SRPP followed by a E88CC cathode follower. The equalization is active between the third and first stage. The active mode gave better S/N than a passive one between the first and second stages. I sympathize with the problems you have experienced with measurements. I have a raft of test gear incl 2 DSO, a HP distortion analyzer, two signal generators and more meters than I can count. Still the process of measuring RIAA preamps is both tedious and can be misleading. When I get it a little closer to what I want, I'll post it.
Where did you get the power transformer? Small ones for this type of project are difficult to locate except through overseas sources.
Previous Topic: IR Remote Control
Next Topic: Build a Synthesizer
Current Time: Sat Nov 07 04:35:30 CST 2026
