Home » Audio » Craftsmen » Sub Box (Questions for a build)
Re: Sub Box [message #67132 is a reply to message #66978] Wed, 20 April 2011 12:12 Go to previous message
FE3T is currently offline  FE3T
Living in a country with temperatures from -30 Celsius in the winter, tp +30 Celsius in the summer, and since i have mostly been driving 20 year or older cars, i know all about moisture in the trunk.
My method are either to use waterproof fibreboard (bathroom flooring) or if using MDF to paint all surfaces. (outside and inside) with thinned PVA glue before applying any carpetry.
index.php?t=getfile&id=355&private=0
22mm Water resist fibreboard
index.php?t=getfile&id=356&private=0
carpeted and completed.
This was made to be a squeze fit in a 88 Mazda 626 Coupe (or MX6 for the US citizens)
  • Attachment: Bassbox02.jpg
    (Size: 70.34KB, Downloaded 2478 times)
  • Attachment: Bassbox05.jpg
    (Size: 75.98KB, Downloaded 2627 times)
Previous Topic: Will Longer Wires Reduce Sound Quality?
Next Topic: Veneer advice
Current Time: Thu Nov 05 03:05:13 CST 2026
