Home » Sponsored » Pi Speakers » best choice for DJ studio
icon5.gif  best choice for DJ studio [message #67089] Sun, 17 April 2011 10:04 Go to previous message
homer09 is currently offline  homer09
The need: fill a 12x24' foot room (separated by a partial wall into two 12x12' rooms) with a lot of volume for a DJ studio/practice pad. The music is mostly house/techno so bass is an important requirement.
the budget: small (a few hundred at first, maybe more later)
amps: TBD
fabrication ability: beginner, low
looking at the complexity and cost of the speakers, the two pi towers mated to a sub looks like the best option. higher numbers seem a bit out of the fabrication skill level and budget.
so basically, my question is: will the two pi towers and sub fill a 12x12 room with almost ear bleeding volume and controlled/loud bass? and then maybe another pair to take care of the second 12x12 eventually?
also how difficult is the build for the two pi? is it simply a box or is there more to it inside? how about the sub?
Previous Topic: Info to compare Pi models
Next Topic: 3Pi - 4Pi In Nearfield, <7 feet?
Current Time: Wed Oct 21 07:22:36 CDT 2026
