Home » Sponsored » Pi Speakers » Driver selections (4pi)
Re: Driver selections [message #66835 is a reply to message #66830] Fri, 01 April 2011 15:13 Go to previous message
That is a tight fit when you use the three-hole mounts instead of the two. When using the two hole mounts, it's easy. But the three hole mounts are right up close to the body. I use an open end socket wrench to tighten these bolts.
Previous Topic: Wayne, which speaker for PA tops?
Next Topic: One pi plans please
Current Time: Thu Nov 05 22:10:06 CST 2026
