Home » Audio » General » Sound in Car
Re: Sound in Car [message #66814 is a reply to message #66810] Thu, 31 March 2011 17:34 Go to previous messageGo to previous message
It is a mediocre equalizer, let's see what happens when you turn these up:
40 - More Hum
100 - More Oomph
250 - More Punch
625 - Breathy? Hoarsey?
4k - Sharper guitars and vocals
12k - More cymbals. This f is very sensitive to direction
16k - More distortion for MP3, more cymbals and cymbal decay for CD.
Of course you should set everything how you like it, then go back and make the loudest one the new "0" and adjust the rest to fit the curve.
I wouldn't boost the 250, 625 or 4K ones at all. I would cut them and work around the cuts.
So if I ended up with:
40 - +3
100 - +5
250 - +7
625 - +5
4000 - +3
12000 - +5
16000 - +3
I would re-eq it to:
40 - -4
100 - -2
250 - 0
625 - -2
4000 - -4
12000 - -2
16000 - -4
It is MUCH more complicated than that due to the Q value changing and all. Look it up if you want a long read, some difficult math and a lot of confusion. But basically the more boost or more cut the more frequencies around it are affected.
You could do it as above, you you could never let anything from 250-4Khz go above zero.
Previous Topic: Purpose of Music Formats?
Next Topic: Musical Toys
Current Time: Wed Nov 04 18:06:42 CST 2026
