Home » Sponsored » Pi Speakers » Gonna energize my 4Pis
Gonna energize my 4Pis [message #66648] Sun, 13 March 2011 22:24 Go to previous message
Pretty soon I'll be blasting HUGE wattage thru them. No more 2 watt 45s or 6 watt 6CA7s, no sir. I just orderd this powerhouse T Amp with an astounding 12 Watts into 8 Ohms!
http://i.ebayimg.com/00/$(KGrHqIOKjQE0idK54)RBNZ6HRBDtQ~~_3.JPG
I ordered this partucular one because the vendor was the only one with 8 Ohm numbers and he included the following totally accurate description:
"The Topping T-Amp is a so-called Class T integrated amplifier, based on the TA 2020 chipset. the chip makes use of a kind of "Digital Power Processing", this is, more or less, a Class D amplifier with high rate switching properties. That is why they put the word "digital" into it. Actually, there's nothing really digital inside, not in terms of D/A conversion. You can view the official TA2020 datasheet, with detailed tech specs, The Topping T-Amp is nothing else than a pure and simple application suggested by the chipset datasheet. No magic"
I also like the parts selection
http://i.ebayimg.com/00/$(KGrHqIOKk!E0bc2p1L3BNZ6H,jydw~~_3.JPG
Having it also means my grand daughter can safely be around the stereo or TV which is really reason number one!
Should be interesting...
Previous Topic: 4 pi: impressions of a newbie
Next Topic: My 4pi Build Report
Current Time: Thu Nov 05 03:41:02 CST 2026
