Home » Sponsored » Pi Speakers » 4 pi crossover frequency
Re: 4 pi crossover optimization [message #66638 is a reply to message #66635] Sun, 13 March 2011 10:48 Go to previous messageGo to previous message
Do not suppose that the crossover frequency is all that is important, or even that it is most important. Certainly, you do not want to try to push a driver beyond its usable passband but even if you get that part right, if the phase relationship between the two adjacent sound sources isn't right then the forward lobe will be ill-formed. You'll find response ripple in the crossover region, straight on-axis and pretty much everywhere else.
If you are looking for best performance, you can only swap drivers if you redesign the crossovers. You can only "mix and match" drivers with an existing crossover if your expectations are moderate, seeking only a rough approximation of balanced response.
For more information on the crossover design, see the following documents:
Previous Topic: 4Pi
Next Topic: L pad on crossover?
Current Time: Fri Nov 13 09:44:50 CST 2026
