Home » Sponsored » Pi Speakers » 4 Pi Baffle Information
Re: 4 Pi Baffle Information [message #66460 is a reply to message #66458] Thu, 03 March 2011 11:11 Go to previous messageGo to previous message
The outer dimensions are correct for the woofer, but the horn is sometimes a bit snug when routed using Eminence's dimensions. I'm not sure if there's a little bit of variance from horn to horn but I know I've had trouble there. If the cabinet is unfinished, obviously it can be re-routed but I've had some cabinets delivered finished and then when I went to install the horn, it was anywhere from 1/32" to as much as 1/8" too large. Seems more often that it is too wide than too tall. In a couple cases, rather than re-do a cabinet that was finished with an expensive polished laquer coat I had the horn planed to remove some of the edge. Turned out great, so don't be overly alarmed, but it was frustrating to find the horn didn't fit and have to take extra steps to correct it.
Previous Topic: JBL 2425 Diaphragms
Next Topic: Helper Woofer Location
Current Time: Fri Nov 13 01:33:49 CST 2026
