Home » Sponsored » Pi Speakers » 2226j (16 ohm) usable? (question about 4pi)
Re: 2226j (16 ohm) usable? [message #66373 is a reply to message #66369] Sun, 27 February 2011 21:35 Go to previous messageGo to previous message
I'll send plans. You can see a spec sheet at the link below, which has an impedance chart.
As for the (16Ω) 2226J, try and avoid it if you can. You can scale the low-pass components but that will leave you with a speaker that still has less voltage sensitivity, so you have to increase padding on the tweeter to compensate by changing R1/R2 values. Best to stick with the (8Ω) 2226H.
Previous Topic: Tweeter Change (again !)
Next Topic: Four Pi R3 Mounting
Current Time: Sat Nov 28 18:54:13 CST 2026
