Home » Audio » Speaker » The Bigger the Better?
Re: The Bigger the Better? [message #66270 is a reply to message #66216] Wed, 23 February 2011 07:20 Go to previous message
I've had these for almost 20 years now.
http://www.google.com/images?hl=en&biw=1120&bih=615&tbs=isch%3A1&sa=1&q=technics+sb+a26&aq=f&aqi=&aql=&oq=
I don't really care what shortcomings they have because I can correct it before it even hits the speakers.
I think might upgrade them to Cerwin Vega XLS-215's one day though. The advantage is that they get down to 24hz, while mine get down to 35hz. They stop at 20Khz, while mine stop at 40Khz. I am pretty sure some crossover surgery can get them to pass 20-40Khz though the tweeter.
Again. If you insist on amplifying the original source to line level, then sending through a power amp untouched, big nasty loudspeakers might not be for you. But if you have a half-dozen processors that can make a signal as flat or as coloured as you want it, the speaker size becomes a limitation if they are too small.
Previous Topic: Speakers in the Wall
Next Topic: Old speaker or amp that's creating noise?
Current Time: Wed Oct 21 18:07:36 CDT 2026
