Home » Audio » Pro Sound » Best audio editing software for beginners?
Re: Best audio editing software for beginners? [message #66175 is a reply to message #66148] Fri, 18 February 2011 11:53 Go to previous messageGo to previous message
Have you checked out a program called Goldwave. It's basicaly a shareware program but the licenses are cheap. It's a little known secret among recording studios. They have plenty signal processing and effects built in, but one of it's strengths is you can go in and redraw the waveform if you overload the A/D converters and eliminate the distortion.
http://www.goldwave.com/index.php
HTH
Bill
Previous Topic: Microphone recommendation?
Next Topic: Audio format converter?
Current Time: Wed Oct 21 05:07:23 CDT 2026
