Home » Audio » Craftsmen » High-Pass Filter
High-Pass Filter [message #66172] Fri, 18 February 2011 09:07 Go to previous message
Alright, so I noticed something playing with a band.
The speaker excursion of my all-in-one PA system is very high. The 5-band EQ on the thing only goes down to 250hz and I suspect that frequencies below that are responsible. I have a bass-heavy voice, even when singing well above middle-C and a heavy attack and am concerned it is going to blow the amp or the speaker. The clip meter comes on at the height of the attack and not really at any other time. I am pretty sure it wouldn't be clipping at all if I could tame the low-end and then I can get the full wattage of the system.
Does anyone know the values of the capacitor and the resistor I would need to make a 200hz high-pass filter off the top of their head that I could wire directly into the microphone's shell?
A windscreen is simply not going to be good enough.
Previous Topic: Don't want to mess with the carpet...
Next Topic: lubricants for audio
Current Time: Thu Nov 05 06:17:18 CST 2026
