Home » Audio » General » What are possible future audio innovations?
Re: What are possible future audio innovations? [message #66118 is a reply to message #66103] Mon, 14 February 2011 12:09 Go to previous messageGo to previous message
GoodVibrations is currently offline  GoodVibrations
Adveser wrote on Sun, 13 February 2011 20:14
Well, a higher bit-depth is going to result in a much more accurate recording.... A good classical recording during a soft passage will be presented at a much higher resolution at lower volumes. Hypothetically going from 12bits to around 20bits of information for the same sound (Example numbers)
Thanks for the explanation, that makes it easier to understand. I have listened to a few songs where the singer's voice is very soft and low and I have to turn the volume way up to try to understand the words being sung. With the 24bit-depth, it should be much clearer and easier to hear without turning up the volume.
Music is a tonic for the tired and weary mind
Previous Topic: XBox One Audio
Next Topic: 3Beez Wax Music Management System
Current Time: Thu Nov 12 04:39:02 CST 2026
