Home » Audio » Room Acoustics » Where To Learn More?
Re: Where To Learn More? [message #65873 is a reply to message #64964] Sat, 29 January 2011 12:33 Go to previous messageGo to previous message
Yes. There is. Every book on audio engineering and mixing I have found could be called "audio for dummies"
Those books are easy to read and they explain how sound works effectively enough.
The Human range of hearing is 20hz-20,000Hz (20hz-20Khz) though most people's hearing stops between 15-17Khz.
Response is generally considered the electrical output/conversion to acoustic energy (which is the movement of the speaker, not be confused with "acoustics"). I am not sure, but I think the specs are what works in a vacuum where there is no such thing as room acoustics. You can take a speaker's response as 20-40000hz as being just that. The only qualifier is the amount of space between yourself and the speaker that is required to produce a complete waveform of 56.5ft at 20hz, ~28ft at 40hz, ect.
I am not sure though because I have heard conflicting information about the ability to hear a waveform even if it physically can't exist in a space. I've been told that headphones can only reproduce the frequencies that can fit between the space between the speaker and the inner ear, but if that were true, why can I play a 20hz tone through them and it sounds like 20hz? Wayne, do you know what the deal is with this?
Check your PMs, jl
Previous Topic: Adding Echo
Next Topic: Pipe In Music
Current Time: Sun Nov 22 23:26:22 CST 2026
