Home » Sponsored » Pi Speakers » [Pi2 Tower] Insulation on braces
Re: [Pi2 Tower] Insulation on braces [message #65588 is a reply to message #65569] Thu, 06 January 2011 09:12 Go to previous messageGo to previous message
Wayne,
In the picture provided is that the 2pi tower without the baffle?
If so you have 3 sets of braces but I would swear the plans say I would use 2 braces. 1 set under the woofer and the other set 15" up from the bottom. Did you just maybe make a place for the insulation to sit up at the top of the cab and maybe it isnt a brace?
You also say the braces should be slightly preloaded. Does this mean that you would build the cab as shown without the baffle and the braces cut ever so slightly bigger so they have to be somewhat forced into the cab creating a tight fit?
Previous Topic: Help with tweeter to woofer distance please
Next Topic: 2 pi tower baffle
Current Time: Thu Nov 05 22:19:21 CST 2026
