Home » Sponsored » Pi Speakers » seven π plans (information request )
seven π plans [message #65502] Sun, 02 January 2011 00:12 Go to previous message
ohiogaucho is currently offline  ohiogaucho
Wayne Parham,
Please send me seven π plans. I am hoping that they include a schematic of the crossover.
I will consider adapting your mid horn for use with B&C 6 PEV 13 6" midranges I have on shelf. That will probably require my adding a square conical throat extension to neck down to 8-9 sq in throat. Back volume would be about 1/3 cu ft, and front volume would be minimal (between baffle and cone). This driver does have a phase plug. There is adequate setback of the cone and suspension to avoid slap on the baffle. Minor tweak of the crossover will also be required, probably.
B&C 6 PEV 13 spec: http://www.parts-express.com/pdf/294-650.pdf
Thanks,
Bob
Previous Topic: How to measure T-S Parameters
Next Topic: Bamboo Plywood
Current Time: Thu Nov 12 03:39:25 CST 2026
