Home » Audio » Room Acoustics » Speakers on Sand?
Re: Speakers on Sand? [message #65432 is a reply to message #65285] Mon, 27 December 2010 17:11 Go to previous messageGo to previous message
Wonderwoll wrote on Wed, 15 December 2010 04:05
I've heard of the sand trick before but don't you have to dry it out for the maximum effect? Or is there some special type of sand you should use?
I think any sand you'd have in the house would be dry. I don't think it makes much difference. The vibrations are being broken up by the deformity of the tiny crystal "rocks" that make up sand. Adding water isn't going to change anything but maybe speed up the transfer between the material a bit.
Previous Topic: Best place to put subwoofer
Next Topic: Making a Recording Studio
Current Time: Sat Oct 31 21:41:48 CDT 2026
