I'll have to check that SB29 tweeter out, sounds like. Thanks for the heads up!
Of course, the one π and two π models are designed to provide good sound quality and high efficiency on a limited budget. They're intended primarily for surround speakers and secondary systems where high efficiency, sound quality and cost are factors. The SB29 is twice as expensive as the DX25, so it definitely would push the cost up but it might make a good upgrade option.
